Speakers pop when fridge/freezer turns off...
rn2
rn2
13 Mar 2017
England
Every time my fridge/freezer turns off my speakers pop, it's annoying. Is it damaging them or my computer when this happens?
These speakers are old from ebay but I had a pair exactly the same last year with no popping issues. I had to use a different power cord into them as they arrived with a broken one (the one i am using is from my old samsung monitor and is 3amp 250v).
My recent USB powered speakers did not pop but they are USB powered.
I am guessing that the problem is the fridge/freezer which is in a seperate room.
Should I buy an uninterruptible power supply? Buying a new fridge/freezer is not really an option as it still works fine and I rent so I would have to inform the landlord and I don't think he will replace it. But if it comes down to buying one of these should I be getting one that at least matches the wattage of my equipment as they don't seem to be very high wattages on these UPS's.
Sorry I thought this would be network related too I should have put it in General. I will contact landlord soon but still might buy a UPS as the electrics where I live are very old.
I think the suppressor on your fridge isn't working, it shouldn't feed anything in to the wiring at all
This ^
If you're handy with DIY and know how to work safely, have a go at replacing it yourself. If not, get the fridge looked at by the local repair guy.
Thank you guys, my landlord is coming this week with an electrician I think to have a look at it.
Still thinking about purchasing a UPS. I didn't notice the speakers popping at all on my last speakers though so could it be the speakers them selves? The Fridge/Freezer is still obviously effecting them I guess.
Interference might not be going through the mains though - the amplification circuitry might be susceptible to picking up RF from something switching like the fridge.
So blaming the fridge freezer was unecessary? or only to a point? To be honest the fridge freezer is 8 years old and a newer one would be more energy efficient.
My point was that a UPS won't necessarily stop it happening.
Babe amp with a decent power supply might resolve the situation.
Not ideal though as problem is the fridge.
Get a cheap set of pc active speakers as they usually have poor power supply so that will show its the fridge
The Fridge is being replaced this week, Got a new PSU anyway and just waiting for it to be fitted now.
