Spec ~£300
27 Oct 2007
Hi all,
Thoughts on a spec for ~£300-350 for my parents? Will be used for Office, light internet usage, and Skpe. Not a lot else. Onboard GFX will be fine.
Don't need a case or monitor.
I have an oem version of vista 64 - assume I can use this on this build as well (legally)?
Many thanks in advance for any spec suggestions.
Hi all,
you can only use this if it is not already installed on any other machine mate...spec coming up....
You could just plump for one of these:
"Primo Compact" Intel Pentium Dual Core E5200 2.50GHz System
£275.99 inc VAT
Stock Code: FS-163-OK
Product Name Qty Price Line Total
Gigabyte GA-EP43-S3L Intel P43 (Socket 775) PCI-Express DDR2 Motherboard £74.74
(£64.99) £74.74
(£64.99)
Corsair HX 450W ATX Modular SLI Compliant Power Supply (CMPSU-450HXUK) £64.99
(£56.51) £64.99
(£56.51)
Intel Pentium Dual-Core E5200 "LGA775 Core 2" 2.50GHz (800FSB) - Retail £62.09
(£53.99) £62.09
(£53.99)
Gainward GeForce 9400 GT "Silent" 1024MB DDR2 HDTV/DVI/HDMI (PCI-Express) - Retail £45.99
(£39.99) £45.99
(£39.99)
Samsung SpinPoint F1 320GB SATA-II 16MB Cache - OEM (HD322HJ) £40.24
(£34.99) £40.24
(£34.99)
Kingston HyperX 4GB (2 X 2GB) DDR2 8500C5 1066MHz Dual Channel Kit (KHX8500D2K2/4G) £34.99
(£30.43) £34.99
(£30.43)
Samsung SH-S223F/BEBE 22x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £17.24
(£14.99) £17.24
(£14.99) Sub Total : £295.89 Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.00 VAT is being charged at 15% VAT : £45.88 Total : £351.77
OEM windows is tied to the board it was originaly installed on, new motherboard new license required.
You can upgrade any part bar the motherboard.
Retail allows you to install on any system belongs it is unistalled from the last install.
yeah, my research just told me that - thanks.
Recomendation is for a gfx card then, not on board? Why?
Spec would be suitable for HD web cam I assume, as this is something she is after?
Thanks again for your help.
most half decent boards dont come with on board graphics, and i could fit it into the budgrt, complaining.? :p will come in handy when your watching HD movies etc later on if you want/need too.
and yeah HD webcam will be fine mate :)
You'll obviously need an os to install on it too if you only have an oem version of vista?
EDIT: save yourself 90 quid on this build then without the oem version of vista
This, just no dedicated graphics mate
Asus M3A78 Pro AMD 780G (Socket AM2+) PCI-Express DDR2 Motherboard £77.04
(£66.99) £77.04
(£66.99)
(£56.51) £64.99
(£56.51)
AMD Athlon 64 X2 Dual Core 7750+ Black Edition 2.70GHz (Socket AM2+) - Retail £57.49
(£49.99) £57.49
(£49.99)
(£34.99) £40.24
(£34.99)
(£30.43) £34.99
(£30.43)
(£14.99) £17.24
(£14.99) Sub Total : £253.90 Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50 VAT is being charged at 15% VAT : £39.51 Total : £302.91
Kenny why do you keep suggesting the corsair modular psu? there really is no need for such an expensive power supply for a pc that's mainly going to be used for microsoft office and light internet browsing, it's pure overkill.
There is also no need for 1066Mhz memory, 800Mhz is adequate.
and that is a top quality power supply. - quiet, less likely to blow on you, (if it does blow less chance of taking out anything else with it)
you you read these forums.?
with a decent budget you would always invest in a decent power supply coupe69er
(£66.99) £77.04
(£66.99)
(£56.51) £64.99
(£56.51)
(£49.99) £57.49
(£49.99)
(£34.99) £40.24
(£34.99)
(£30.43) £34.99
(£30.43)
Coolermaster Elite 335 Case - Black (No PSU) £28.99
(£25.21) £28.99
(£25.21)
(£14.99) £17.24
(£14.99) Sub Total : £279.11 Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.25 VAT is being charged at 15% VAT : £43.55 Total : £333.91
