Right, i currently have the coolermaster elite 430 windowed.
It's a good case on a budget, but i reckon that if i ever want to crossfire down the line(i probably will) then it would be best to get something with a little more room, or at least better cable management.
I am looking at this
http://www.overclockers.co.uk/showproduct.php?prodid=CA-182-LL
Thoughts anyone?
i'll spend a max of £100 i think.
i currently have a 5850, which is fine at the moment, and will be for a while tbh, but when i do need a bit more, i will probably crossfire instead of getting a new card(i'm thinking of 6months- a year)
Also, i am going to get an AM3+ board with crossfire support when they come out, as my current board doesn't support crossfire.
any case suggestions would be helpful, especially if you have personal experience.
Cheers guys
Edit- Forgot to say, would prefer a side window, but not essential for a good case.
I currenltly only use 1 5.25" front bay, so two are probably needed at the most.
Thoughts anyone?
Cheers guys
