Spec a phone > Motorola G6 ?
23 Nov 2004
Hi,
The Mrs Motorola G6 has had water damange and no longer works. I've got her working on my old OnePlus5, but she finds it too big.
Can anyone reccommend a new(ish) model of phone that has similar dimensions to the Motorola G6 please? Struggling to find a way to search for a phone by its bloomin dimensions!
Needs to be Android + half decent camera.
Thanks
Almost no phones are that size now.
I managed to get a good deal on a Samsung s21 earlier this month (£23/month, £75 up front), but I was waiting ages for a good deal on a small phone, and the deal I got is no longer available.
S22 is same sort of size, but expensive. Sony 10 is also small, but expensive for a pretty low end handset.
Use GSMarena to compare sizes.
Hey,
Thanks for replying. Yep, I thought that but understand her dislike for it. I didn't like going from the OnePlus 5 to the Pixel 6 but I soon got used to it. She has been on the OnePlus 5 for a couple of months and still complains it's too big.
However, looking at Compare Motorola Moto G6 vs. OnePlus 5 - GSMArena.com which compaes their dimensions, I can't actually see much difference!
It will be a Phone only purchase as she uses minimal data/calls on GiffGaff that suits her usage.
Hi,
Thanks
Handy tool for this is the GSMArena's Phone Finder - https://www.gsmarena.com/search.php3?
Obvious choice would be a iPhone SE but if it's Android then Sony Xperia 10/Xperia 10 Lite, Samsung S22 or S21, Xiaomi 12, Pixel 5/5a are all similar sized to the G6. Although it's worth looking at phone slightly larger as you'll likely get better hardware....
Pixel 5 would've been my recommendation especially if she wants a good camera, but it's a bit hard finding one brand new these days. Smaller than the G6 especially the width, I suspect it's the OP5 being oh so slightly wider that could be making it slightly uncomfortable.
