Would appreciate some advice on an initial build that was spec'd for me built around a E6300 and a X1950pro.
Firstly, I was recommended the Gigabyte GA_945PL_S3 (Socket 775) but now I'm concerned that the 800MHz FSB limitation is going to seriously handicap the system. Would I be better off going for a 965 based board? Recommendation?
Secondly, I ordered a Enermax Liberty 400W ELT400AWT PSU. At 400W is this going to be plenty to power the system (it is classed as SLI compliant so I would have thought it had enough juice)
Thanks..
Thanks..
and i still play new games on max settings with zero problems (might have some trouble with crysis
since it seems to been fully recommended in other posts and reviews.
