Spec Check/ First SFF Build.
Um I get why you are suggesting a smaller PSU, but you've got to take into account that in order to fit this the OP is going to have to do some modding to get it mounted. Just thought he should know.
I've got the same PSU (OCZ 500W) in my V352 and yes it is a little annoying it lifts the PSU 1mm, but it doesn't affect the performance and to be quite honest for the cost of it you can hardly complain.. is it really worth getting a new PSU because of some minor scratches?
Yeah to be fair the cost of the psu was ok, ill whip it apart and take a pic of the scratches and my attempt at cable management tomorrow..
Just a quick update, will be getting an SSD, and possibly some better cooling, im just waiting to get paid from work to be able to do so.
Once i do i will take some pictures of the install since to install all of this i will have to take the tiny beast completely apart.
Just wondering if anyone has ever tried cable braiding, as i fancy having a go to see if i am able to get better flexability out of my power cables.
