I started this in another thread where I asked for thoughts on a rig that will be purely used for gaming & maybe light photoshop work(but this isn't likely at least in the short/medium term). Ideally I'd like to be using this rig for a good few years, my current rig is 7 years old with an i7 860, which I put some more RAM & a 970 in a 18 months ago.
https://forums.overclockers.co.uk/showthread.php?t=18738942
It was suggested that I get a better Mobo & would 2400Mhz memory would be better, fair enough so I've updated the spec to the below.
My basket at Overclockers UK:
Total: £2,016.35
(includes shipping: £0.00)
But I've been pondering a X99 system as well, what is everyone's opinion on a 5820 vs a 6700k with the following?
Total: £2,017.35
Thanks.
- 1 x Corsair Vengeance 16GB (4x4GB) DDR4 PC4-19200C14 2400MHz Quad Channel Kit - Black (CMK16GX4M4A2400C1= £73.99
- 1 x XFX XTR Series 850W 80 Plus Gold Fully Modular Power Supply= £119.99
- 1 x Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU)= £149.99
- 1 x Phanteks Enthoo Evolv ATX Glass Mid Tower Case - Gun Metal= £164.99
- 1 x Phanteks Multicolor RGB LED Strip - 2 Metres= £16.99
- 1 x KFA2 GeForce GTX 1080 "Reference Blower" 8192MB GDDR5X PCI-Express Graphics Card (80NSJ6DHK5VK)= £575.99
- 1 x EK Water Blocks EK-FC1080 GTX - Acetal+Nickel= £90.95
- 1 x EK Water Blocks EK-FC 1080 GTX Backplate - Nickel= £30.95
- 1 x OcUK Tech Labs - V12 Watercooling Kit 360 = £273.85
- Tubing Colour
rimochill Primoflex Advanced Tubing 16/11 - Clear - Coolant Choice:Mayhems X1 UV Oil Black Premixed Watercooling Fluid 1L
- Radiator:Coolgate G2 Radiator 10 FPI - 360mm
- Pump & Reservoir Option:XSPC D5 Photon 170 Reservoir/Pump Combo
- CPU Block:EK Water Blocks EK-Supremacy EVO - Acetal+Nickel
- Tubing Colour
- 2 x EK Water Blocks EK-ACF Fitting 12/16mm - Nickel= £3.79
- 2 x XSPC G1/4" Plug (Chrome)= £1.55
- 1 x Asus Maximus VIII Hero Intel Z170 (Socket 1151) DDR4 ATX Motherboard= £187.99
- 1 x Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor - Retail= £319.99
Total: £2,016.35
- Tubing Colour
- Tubing Colour
- 1 x MSI X99A SLI Plus Intel X99 (Socket 2011) DDR4 ATX Motherboard= £178.99
- 1 x Intel i7-5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75820K)= £329.99
Total: £2,017.35
Thanks.
