I already have my Silverstone Ft01 case, but these are the rest of the components that I was hoping to order today or tomorrow. Does it look ok, as it's a first time build?
AMD Phenom II X4 Quad Core 940 Black Edition 3.0GHz (Socket AM2+) -
Noctua NH-U12P CPU Cooler (Socket AM2/LGA775) £48.29
Asus M3A79-T Deluxe AMD 790FX (Socket AM2) PCI-Express DDR2
G.Skill 4GB DDR2 PK PC2-8500C5 (2x2GB) CAS5 Dual Channel Kit (F2-8500CL5D-4GBPK)
BFG GeForce GTX 285 OC 1024MB GDDR3 PCI Express 2.0 Graphics Card -
- Memory: 1024MB GDDR3
- Memory Clock: 2484MHz (Effective)
- Shader Clock: 1512MHz
Zalman ZM750-HP Heatpipe Cooled 750W Modular Power Supply
Samsung SpinPoint F1 750GB SATA-II 32MB Cache - OEM (HD753LJ)
Samsung SH-S202N/BEBN 20x DVD±RW IDE Dual Layer Lightscribe ReWriter
I've gone for the GTX285 rather than the 260 (even though it's a lot more money) because I don't intend to upgrade fthe GPU for some time. If you go for a top of line 285, will you see much difference from the lower end? One last thing, are BFG a good make or should I be looking at EVGA? Hope this all seems to cobble together reasonably well?
Thanks for checking.
