Spec Check
18 Oct 2002
Nordschleife
Product Name Qty Price Line Total
Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard £175.99
(£149.78) £175.99
(£149.78)
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66GHz (Nehalem) (Socket LGA1366) - OEM £167.99
(£142.97) £167.99
(£142.97)
Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (TR3X6G1600C9) £142.99
(£121.69) £142.99
(£121.69)
Corsair H50-1 High-Performance CPU Watercooler (Socket LGA775/1156/1366/AM2/AM3) £66.99
(£57.01) £66.99
(£57.01)
Will be going inside an Antec 300 case, any problems with the H50 in there?
Would change the mobo and ram,
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard £151.99
cheaper and it does amazingly good in the benchmarks even came ahead of the UD7.
OCZ Obsidian 6GB (3x2GB) DDR3 PC3-12800C9 1600Mhz Triple Channel Kit (OCZ3OB1600LV6GK) £114.99
Same as your spec'd ram just cheaper.
Seen some iffy reports about the Gigabyte board?
I plan to buy another 6GB of ram in a month or so is the OCZ stable in 2 pairs of 6GB?
Its for a video editing machine so stable it neeeeeds to be!
There is also a lot of glowing reports aswell... I would go with the ud3r without a doubt.. it is a lot better.
Dont know why you would ever need 12gb of ram.. Not even the lastest cad software dosen't use anyware near that much, let alone video editing!!! But yes the ocz is fine.
Adobe Premiere and After Effects - 6/12GB is what I'll start with and 24GB is what I'll end up with. I'm using 8GB of DDR2 now and its maxed out with just PP
Your basket
(£142.97) £167.99
(£142.97)
(£129.35) £151.99
(£129.35)
(£97.86) £229.98
(£195.72)
(£57.01) £66.99
(£57.01)
Sub Total : £525.05
Updated spec then
Order and should be here tomorrow. Hoping for 4GHz from
Item Qty Price
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66GHz (Nehalem) (Socket LGA1366) - OEM 1 £142.97
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard 1 £129.35
OCZ Obsidian 6GB (3x2GB) DDR3 PC3-12800C9 1600Mhz Triple Channel Kit (OCZ3OB1600LV6GK) 2 £195.72
Corsair H50-1 High-Performance CPU Watercooler (Socket LGA775/1156/1366/AM2/AM3) 1 £57.01
Sub Total: £525.05
FREE SHIPPING (DPD Next Day) Shipping: £0.00
Total Vat: £91.88
Total inc Vat: £616.93
New PC is great! Loving the Intel i7!
