Spec check
11 Oct 2007
London, UK
Hi, need a new home office PC for my parents. Will be used for a stupid long time, so getting modern tech now will help it last longer (they are only now replacing a q6600 based machine).
Budget 500-1000 (less is better) They want it to be very quiet, and relatively small.
Used for MS office, internet, some minor video editing - general office and parenty things, network/printer sharing etc.
can re-use a seasonic 550w psu from their old machine, along with a 512GB SSD for storage, and weve got local and cloud backup sorted already. Mechanical keyboard, steel series mouse, and crappy speakers are already owned by them. Already have windows/office software etc. They currently have a 17" old as sin monitor that needs replacing, either with my spare 30" or if thats too big a 21-24 will be ok if its cheap enough.
This is what Ive specced, I would normally spec lower, but knowing them, they will stll be using it in a decade if they can. Anything you would change?
My basket at Overclockers UK:
Total: £922.43
(includes shipping: £12.60)
Save £30 on the RAM (LEDs but you don't have a window so it won't matter) and upgrade to a 6600K. More overall performance per pound spent :)
Total: £298.68
(includes shipping: £8.70)
In fact, having read the post properly now you could comfortably drop down to an i3. Hyperthreading really helps elevate this CPUs performance, and with a 3.7ghz clock speed I doubt you'll notice the difference from the i5 you've spec'd.
Didn't spot that ram, only picked what i picked as the "fastest before the price seems to hike up rapidly". Will def get the RAM.
Don't really want to drop to a dual core, purely for longevity. Price wise it does make sense though for the usage scenarios. Will think about it.
I would go with a cheaper cooler. Not sure a build like this warrants a £55 Noctua with a locked cpu.
Also same goes for the motherboard. You could easily go with a cheaper H110 board.
Do they need an M.2 SSD ? Something like the Samsung 750 EVO should be fine for an office pc.
Total: £167.47
(includes shipping: £10.50)
