- 11 Aug 2005
- UK
Hey
My current i7-920 (Nehalem) system has done me proud
and I'm looking to upgrade to the new Skylake, so any help, hints, do's, don'ts would be greatly appreciated!
The system will primarily be used for photography work but I'm keen to get back into a bit of gaming!
My current key component build is:
- i7-920 CPU (upgrade)
- Asus P6T Intel X58 motherboard (upgrade)
- BeQuiet! Dark Power Pro 650W (upgrade)
- OCZ Gold 6gb DDR3 PC3-12800C8 (1600MHz) (upgrade)
- Samsung SpinPoint F1 750gb SATA-II (keep or upgrade)
- Corsair Force Series 3 120GB SATA 6Gbs SSD (keep or upgrade)
- MSI Twin Frozr II GTX 580 (keep or upgrade)
Upgrade to:
I tend to leave upgrading until it needs a full overhaul, so the cost can stretch if need be but I don't want to spend unnecessarily either. Will my existing SSD / HDD & GFX be ok?
Cheers
and I'm looking to upgrade to the new Skylake, so any help, hints, do's, don'ts would be greatly appreciated!The system will primarily be used for photography work but I'm keen to get back into a bit of gaming!
Upgrade to:
- 1 x Asus Z170 Maximus VIII Hero - Skylake Core i7 6700K CPU & Motherboard Bundle **£30 Saving**= £489.98
- 1 x Corsair HX750i 750W '80 Plus Platinum Digital Modular Power Supply (CP-9020072-UK)= £119.99
- 1 x Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Black (CMK16GX4M2B30= £109.99
- 1 x Noctua NH-U14S Ultra-Quiet Slim CPU Cooler with NF-A15 Fan= £62.99
Cheers
