Spec Help
6 May 2009
Good setup or not? Suggest me anything
so can you suggest me a water cooling kit for that money?
This method can prove to be a bit expensive - but most people find that they can manage their temps with just the one fireman and as a result it can become quite an economical solution and, more importantly, just as effective!
didn't understand
be clear what's your point
Basically, as 95thrifles has said, your spec is fine, very much like all your others - the EVGA is a wise choice when looking to put a third party cooler on a gfx card.
mjones1, makes a good point about the water cooling - but you may be better served making a dedicated post about water cooling in the overclocking/cooling forum. (if you haven't got a few there already? ;))
However, it would be more helpful if you stuck to the one thread, regarding your overall build, as we would be able to follow your changes more easlily. (And in turn, we'll probably be able to offer more constructive and pertinent advice.)
When do you plan on buying/building this spec?
