Spec help
19 Nov 2007
East London
Aye another of those threads. A friend is looking to upgrade his entire pc with the below. Just wanted to see if its all compatible etc:
PSU: Corsair AX 850
RAM: Corsair Vengeance DDR3 1600mhz 8gb (CL8-8-8-24)
CPU: i7-3770k
CASE: Haf-X
MOBO: MSI Z77 MPower
HDD: Samsung 840 256gb SSD + 1TB seagate hdd
GPU: Gigabyte 680gtx windforce
COOLER: Corsair H80 hydro
He's from another country so there are limitations in what he can get so hes pretty much certain in the above. Just wanted to know if those will all fit together?
Ta.
no idea what dimensions r needed, but i would make sure you can fit that H80 in that case. a web note would do to overclockers.
If its just for gaming its a bit over-spec ed. You could easily save a lot of money. Is that something you'd be Interested in?
Otherwise it all works fine together.
A h80 should fit in a haf x easily.
