Spec help
19 Nov 2007
East London
Hi all,
Need a quick build for a work colleague. Heavy FX user/trader.
Below are the minimum specs required:
CPU: i5
RAM: 8GB
HDD: 256gb SSD
OS: Win 7 pro 64 bit
Graphics: ATI FirePro 2450
Monitors: 4x 22 inch DVI/VGA monitors
+ the other bits like tower psu etc.
The only other requirement is to be as cheap as possible.
Cheers.
Hi, sorry been away for a few days.
No real budget, but as low as possible I think. Just had a few follow up questions:
Will the FirePro have any compatibility issues with that mobo or?
Will that psu be able to power all those monitors connected together?
Is there a specific type of adapter I would need to connect those 4 to the graphics card?
Thanks
