- 28 Jul 2009
![Confused :confused: :confused:](/styles/default/xenforo/vbSmilies/Normal/confused.gif)
It will be used for gaming + encoding
Cheers
What about AM3?
im a bit of an amateur but this is the i7 build i was planning on
Monitor Samsung SM2333SW LCD 23"
Processor Intel I7-920
Motherboard Gigabyte EX58 UD3R
Chassis Thermaltake V9
RAM Corsair XMS3 DDR3 6GB
Graphics Card ATI Radeon HD 4890
HDD Seagate Barracuda 500GB
Power Supply OCZ 600W
Fan Megahalems
OS Windows 7 professional
comes up to £1100
No thanks, I want to go with Intel my heart is set on it.
how about this mate may be a bit over your budget:
Antec 902 case
core i7 920 (overclock it)
Gigabyte x58 ud5
12gb xms3 1600mhz corsair
powercolour 4890
wd 500gb black x2 (raid 0)
sony lightscrive dvd burner
windows 7 (when it comes out)
Corsair 750w psu
h50 corsair watercooling
Because Raid 0 is for speed.Why bother with the two 500GB drives, when one 1TB drive costs less than 2 500GB ones.
Or is there a reliability issue with the 1TB drives?
There's a bigger reliability issue with raid 0 than with any terabyte drive
[pedantic]Raid 0 isn't strictly speaking a raid, since there are no redundant disks. [/pedantic]
12gb of ram will not help overclocking, consider carefully whether you'll actually be able to push the system past 6gb before getting the second set. Ideally buy one set, and if you ever manage to run out then buy the second.
"Gaming and encoding" remains terribly unspecific. What games, what res, what encoding? Which matters more? P55 or AMD is likely to dominate for gaming at this budget, but for encoding the X58 chipset will be quicker.
I have a suspicion people quote encoding just to encourage forum people to quote the processor they've decided they want, rather than one which actually fits the requirements. Do you really care if it takes one hour or two to rip a DVD, when you can queue several and leave it running overnight?
