I'm after a pair of 320gb drives for RAID0. not sure on budget but need to get an idea of what the best drives are. Also is a RAID controller worth it if I can afford a low end model or am I better off with the onboard controller?
For RAID0 the only benefit of an add in card is the ability to move the array easily to another mobo. If you're booting from the array then you'd need to do a reinstall anyway so it's even less of a benefit.Any more opinions on the value of a cheap RAID card over onboard RAID? I certainly don't want to spend anywhere near £100 so if I won't get the benefit then I'll leave the card.
Go with the onboard controller.
I think I'd go for 3 x 250GB
