spec me 3 systems
Caporegime
24 Dec 2005
Autonomy
I would really appreciate it if I could get a spec for a family member for
£500
I got an email saying:"We would want to use it for music downloads, digital photos and possibly video, word processing etc"
Must have a 17" TFT and Firewire
EDIT: and now some casual gaming :eek:
Thanks
£600
£500
£400
Thanks
Ouch, I dont think your gonna get much if you need a 17inch TFT, thast £150 gone allready, unless you go 2nd hand :(
KB, mouse too?
Conc
KB, mouse too?
Conc
Yes you will, look what they want to use it for.....I don't see anything where you need a beast of a PC unless I have missed something?
[edit]
Obviously you won't get a TFT in for £400 but otherwise i dont see why not
[edit]
I thought "digital photos and possibly video" was editing them :o
for 500/600 something can be made up, gimme a few mins :)
MB-125-AS Asus K8N4-E nForce4 4X (Socket 754) PCI-Express Motherboard (MB-125-AS)
£49.95 £49.95
MY-004-OK OcUK Value 1GB (2x512MB) PC3200 184pin DDR Memory Dual Channel Kit (MY-004-OK)
£44.95 £44.95
HD-047-WD Western Digital Caviar Special Edition 160GB 1600JS SATA-II 8MB Cache - OEM (HD-047-WD)
£49.95 £49.95
CD-025-NE NEC ND4550 16x16 DVD±RW Dual Layer ReWriter (Silver) - OEM (CD-025-NE)
£25.50 £25.50
CA-040-AN Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU (CA-040-AN)
£65.50 £65.50
MO-011-OK OcUK Gamer Emprex 17" LCD Monitor - Black (MO-011-OK)
£129.95 £129.95
CP-138-AM AMD Sempron 64 2800+ 1.6GHz (Socket 754) CPU - Retail (CP-138-AM)
£45.95 £45.95
GX-032-HT HIS Excalibur ATI Radeon X300SE 256MB Hyper Memory DDR TV-Out/DVI (PCI-Express) - Retail (RX300LE-256) (GX-032-HT)
£32.95 £32.95
Subtotal £444.70
VAT £77.83
Total £522.53
..something to work around
thanks jaxon ;)
anyway update.I eamiled just to make sure theres no casual gaming going on and there is!
email just come in:
"despite having a PS2, PSP, game cube and a nintendo DS the kids want to play games"
and now the budget is definatly £500 :eek:
come on peeps :p
You could take Jaxon's suggestion. Change the Hard Drive to an 80GB SATA and change the case to an OCUK Value case or an ASUS case for a better PSU. That should bring you >£500
the x300 SE wont play games though? will it?
Well it all depends on what type of games they want to be playing.
When you say kids are we talking 9/10 or 15/16/17 (if you concider that kids).
They play differnt games. For instance I am pretty sure an X300 will play SIMS 2 for a 9/10 year old but it wouldnt play Battlefield 2 for a 15/16 year old.
I also suggest you have a look at the "B grade" section for some of your components so you can get it on budget.
This is reasonable for the money.
CP-130-AM AMD Athlon 64 3000+ Venice 90nm (Socket 939) - OEM (CP-130-AM)
£89.95 £89.95
HS-029-AK Akasa AK-860 Low Noise CPU Cooler (Socket 754 & 939) (HS-029-AK)
£4.95 £4.95
FS-028-AS Asus Vintage AH1 Barebones System - AMD Socket 939 (FS-028-AS)
£81.50 £81.50
£44.95 £44.95
HD-015-IB Hitachi Deskstar 7K80 80GB ATA-133 2MB Cache - OEM (0A30210) (HD-015-IB)
£29.95 £29.95
CD-044-SO Sony DWQ30AB 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-044-So)
£22.85 £22.85
MO-008-OK OcUK Value L1562S 15" LCD Monitor - Silver/Black (MO-008-OK)
£94.95 £94.95
OS-001-MS Microsoft Windows XP Home Edition inc. SP2 - OEM (OS-001-MS)
£50.95 £50.95
KB-072-LG Logitech Cordless Desktop EX-110 - Retail (KB-072-LG)
£19.95 £19.95
Subtotal £440.00
VAT £77.00
Total £517.00
The 17" gaming monitor that OCUK sells is around £35 more after VAT. I'd suggest either using this spec for about £530 including delivery, or ask for around £575 for the spec with the larger monitor.
Hi there,
Just to let you know, Dace has NOT included a graphics card in there, but he HAS included your operating system, cordless mouse and keyboard but has got a 15" TFT included NOT a 17" as requested
Just bare that in mind...
Thanks...
hottiger said:
The Asus barebones comes with an onboard 9600
they won't want a SFF pc though.
I'm really stuck at what gfx card to get in this budget.
AMD Athlon 64 3000+ Venice 90nm (Socket 939) - OEM £89.95 £89.95
MB-120-AS Asus A8N5X nForce4 (Socket 939) PCI-Express £51.95 £51.95
MY-004-OK OcUK Value 1GB (2x512MB) PC3200 £44.95 £44.95
HD-090-MD Maxtor DiamondMax Plus 10 NCQ 200GB£52.95 £52.95
CD-024-NE NEC ND4550 16x16 DVD±RW Dual Layer ReWriter£25.50 £25.50
CA-000-AR Arctic Cooling T1 Silentium Silent Midi Tower Case - 450W £45.95
GX-098-SP Sapphire ATI Radeon X550 128MB DDR TV-Out/DVI (PCI-E £34.95 £34.95
Subtotal £346.20
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £10.95
VAT £62.51
Total £419.66
this leaves the monitor but I can get one from else where for £120 so this takes it to
£539
which would be ok but what is that gfx card like?
I have no idea about low level pc hardware whats better than the other low level stuff
BTW thanks for the help
IdiotWhoCan'tRead said:
Hi there,
Thanks...
I have clearly stated that it comes with a 15" monitor, I've also stated the price to upgrade to a 17" TFT. The onboard 9600 has already been mentioned.
Its a midi tower, not a SFF.
