Spec me a 24 port switch for home network
Are you doing anything that would require a managed switch?
In general if you have to ask the question then you don't need a managed switch.
And managed is a bit of a blanket term, available features will vary.
Not really I guess.
I think it's between these now:
TP-Link TL-SG1024DE 24 Port Gigabit Easy Smart Switch with Simple Network Set-Up
or the cheaper one:
TP-Link TL-SG1024D 24-Port Gigabit Desktop/Rackmount Switch
Or the trendnet:
TRENDnet TEG-S24Dg 24 Port GREENnet Gigabit Ethernet 10/100/1000Mbps Switch
Decisions, decision....:confused:
TEG-S24G (full length, different to the one you suggested)
Also, look up LackRack
£5 Ikea table for making a super cheap rack!
You can easily cut the legs to make it fit into any height
https://wiki.eth0.nl/index.php/LackRack
Bought a 24 port Trendnet myself this year, hasn't skipped a beat :) One of the lowest power consumption, fanless models I could find.
Can something more than 1U be fitted by adjusting the shelves? I have a server which is 3U on its side I think. This table would be ideal for me, server in the bottom, 24 port managed switch and a patch panel.
These are the options that fit 'U' racks
http://www.ikea.com/gb/en/catalog/products/20011413/#/20011413
http://www.ikea.com/gb/en/catalog/products/80111339/#/00095036
The one with a shelf will fit this in without modification..
Slides in nicely
The legs are hollow, but are reasonably strong. I do stand on the tables, but wouldn't jump on them :D
Package Contents
Power Cord
Installation Guide
Rackmount Kits
Rubber Feet
Mine has arrived today. Very impressed so far. Rackmount kit is in the box. Quite compact too yet feels well built and sturdy! Rewire of my new house starts tomorrow so I'll update you all when its in and running.
