is the i3 2100 better and quicker than the phenom II x6 1055t at a little extra cost
With reapers build. You have the option to drop in an i5 or i7 later on down the line. AMD are dead in the water and any investment into an AMD board is a bit pointless as it leaves the upgrade path non existent.
The cable management on the Coolermaster 430 is quite literally non existent. So a modular PSU will really help out with that. Just makes sure your wife wants blue leds and a see through side panel? If she wants something more conservative.... Fractal do a nice case within your budget.
ahh ok cheers for that ill prob stick with reapers build then or something very similar cheers again peeps
