Spec me a 4k Blu-ray player
26 Oct 2007
Death Star or Mount Doom, it depends on the day.
I want one that does dolby vision and HDR / 10.
It needs to play older Dvds and Blu-Rays upscaled as well please.
I have a LG GX TV with the GX sound bar.
I have this tv and use the Panasonic UB820. I can’t recommend it highly enough.
It’s not the cheapest out there but performance is superb.
I use the Sony UBPX700. Found it to be a very good 4k blu-ray player. Covers the Dolby Vision and HDR10 requirements.
https://www.richersounds.com/sony-ubpx700.html
Having to manually enable/disable Dolby Vision depending on what the disk is encoded with is not something I'd put up with, neither would I put up with having Dolby Vision enabled at all times which is the only other work around.
The Panasonic player will auto detect and enable it only on the disks encoded with it.
I am confused about all this
  • No SACD or DVD-A support
So if I've read it right, of which I doubt I have, are SACDs a special type of CD that won't work in the player?
Yes, SACD is high bitrate and multichannel. If you want to play SACDs then you’ll be best off going Sony as I believe they all support it (being Sony tech and all). It’s always been pretty niche, but saying that I’ve still got about 5 SACDs (live 5.1 recordings of band performances) but nothing to play them on anymore.
If you don’t have any SACDs or not interested in them, don’t worry about it.
Can the Panasonic 820 play files from a network share?
Yes, but I can’t give you any insight as to how well, as it’s not something I’ve touched.
Ahhhh... It must have been a thing I've totally missed. So the DVD-A is the same kind of thing as well? Nope, no interest in either!
Please tell me the panasonic is worth the price...
Im looking at getting a panasonic tv which displays both hdr10+ and dolby vision. Im looking right now for example at the back of Godzilla King of the Monsters 4k disc, and it says it has hdr10+ and DV, so what would a 4kplayer output, or would you have to tell it?
IMO, absolutely. I was also questioning it over Sony’s options but happy I paid a bit extra for the Panny. It’s quiet, solid and has auto DV/HDR10. Remember you can buy bigger, better, quieter players, it’s far from the most expensive player still...
IIRC, If it’s both HDR10+ and DV, it’ll default to HDR10+
Picked up the
PANASONIC DP-UB150 4K Ultra HD Blu-ray & DVD Player for £80 Brand new of someone one E+++ last week.
Bit of a bargain and works perfectly. Doesn't do Dolby vision but my understanding is if the Receiver does that then it will convert it from the 4k blu ray.
Walking through John Lewis Liverpool and I got a bit lucky.
Panasonic UB820 for £100. Opened it at the shop and it looked new. I will test it later and report back.
