My brother is looking to build a pc focusing on VM/Docker/Layers, with a bit of ML and moderate gaming.
Looking in the region of £2k, and I did a rough spec, but I am unsure on what mobo to get, as well as a cooler. I'm guessing AIO would be needed due to the tdp of the 7950x?
Ram I'm guessing 64gb of corsair non-bling 5600 should be fine, and likely going with the £420 3060ti as can't justify the jump to a 4070ti for his needs.
650w to 750w corsair should be fine with all the above?
Thanks for any advice
