- 20 Aug 2013
- Glasgow
I got this for christmas and i'm really happy with it. I use it for espressos but my wife makes lattes with it
Bean to cup machine is where it's at and I was thinking that it was going to cost me a fortune however after a bit investigation ended up buying a machine from Andrew James.
Expected it to be crap for the price but have been nicely surprised.
The only problem I have with it, is if we have a power cut in the night and I just press go without taking any notice of the settings... It defaults to ten cups.
Must have put 20 odd bags of beans through it by now at least. Still consistent as the day it arrived.
(I always refill it from a "brita filter" jug to help prevent scaling)
I took a chance on it for £70 but nope it's been brilliant.
https://www.andrewjamesworldwide.co...8sD54piAW4hy9PjHu2833AUv7cVUPeRgoEaAoja8P8HAQ
HA.
Oh look it's now No1. best seller on Amazon too
Worth bearing in mind that the price is likely due to it being a bean to cup filter coffee machine, with a regular filter machine being perfectly good at £23 from Andrew James. Your machine simply adds convenience of not having an individual grinder.
If you're after making lattes like the OP it's no good, you need espresso for that, which is where things get expensive, especially so for a bean to cup machine.
I've personally got a Nespresso pod machine, it's good and the aerocino thing for frothing milk is good too. I got it as I had a pile of vouchers burning a hole in my pocket, I wanted convenient so espresso wasn't a real consideration and bean to cup was too expensive. The range of different coffees with Nespresso rather than 'flavours' with something like Tassimo appealed to me more.
It's very much a pod espresso machine though, so it only does convenient espresso style pours, rather than makes drinks like other pod machines can. You have to do the rest, with help from the aerocino, if you want a latte or cappuccino or americano etc.
It makes coffee good enough for me, though I'm under no illusion it's the best you can get it's considerably closer to espresso than to instant or filter.
You can buy pods for a Nespresso machine in Tesco and Waitrose... you have been able to for more than 3 years... since before I left the UK...
Still crap compared to a proper bean-to-cup machine though and while the outlay may be marginally more for the bean-to-cup machine (actually, I think I paid 250 quid for a nespresso machine and 220 for bean-to-cup)... you get a MUCH better coffee...
I was referring to the compatible pods, yes - not mis-informed... I've bought them myself
Some are terrible, some are great... some of the Nespresso pods are gross, some are good.
Definitely the best pod machine, I can't disagree with you there... and you say closest to bean-to-cup, not "as good as"
In your post before my last one... you said pods were the easiest to use etc... I had to disagree... bean to cup is just as easy, if not easier and you get a better result for less money in the longer term... let alone less waste created by the lack of pods.
Two posts ago, you said the compatibles are gross, yet in this last post... you say you've never tried them???
You also said buying pods from Nespresso was a downside, yet then you go on to say it's easy to get more.
LOL... swings and roundabouts a little with you
It's not so much about the cost of compatibles... more the convenience of what is available when you run out or simply want added variety... and there are some decent choices available at your local supermarkets.
Nespresso pod machines make nice coffee... I liked the coffee while I had one... no issues.
But, when you are advising someone newer to having their own coffee machine between machines of similar financial outlay... a Nespresso machine or a decent and reliable yet cheap bean-to-cup machine... the bean-to-cup wins hands down for quite a few reasons:
- 100-1000x or more the choice in coffee to drink
- Fresher coffee
- As easy to use or easier than Nespresso
- Option for proper steamed milk
- Cheaper over the course of a couple of years
It's a no-brainer, really...
Please don't go into defensive mode to defend your choice of purchase... I bought a decent Nespresso machine a few years ago... my folks now have it and love it, I liked it while I had it... but given the choice again with what I know now and what's available in the market... I'd have gone straight to the DeLonghi.
But that's like saying you tried the special edition Vanilla Nespresso pod and by default, all the other Nespresso pods are terrible... or you tried a really bad instant coffee and by default, all coffee is bad.
I'm very picky with coffee, I had one favourite pod and two others that I found pretty decent... the rest of them, I didn't like.
Just sounds like you got a bad compatible... they're out there, for sure - I had a fair few... my taste buds don't like having the same thing time and time again, I get used to a flavour and want a change... some of the compatibles are worth trying... even found a fair few over here before we got the delonghi.
I think the bean-to-cup is simpler, because just as you stick a pod in... all you have to do with a bean-to-cup, depending on the size of the bean holder... is fill up the beans once a week or fortnight... so perhaps even slightly less effort than a pod machine
The added benefit being, you can get a much larger variety of coffees... Lavazza Rosso is a good one that most supermarkets stock and there are other good ones too... but the best has to be walking into a place that has fresh roasted the beans that morning and picking up a fresh bag... awesome coffee
You're right in that all steamers can be a pain to clean... although I learnt quite a while ago that you pretty much have to clean it immediately and then it'll be OK. I have a slight preference for steamed milk... so that'll be a personal preference thing... although mostly we just have coffee with cream.
It's fair preference and thanks for debating it with me in the manner you have, I've had some interesting conversations on here that didn't go so smoothly.
It's good to have the viewpoints there so that others can make a more informed decision, whichever may be their preference... I very much liked the Nespresso machine...
im no keyboard warrior for the sake of it but its good to see other Debate their point as you get to see the other side of the fence and some time its greener some times not. I will try some compatibles then and see how it goes i also agree i get bored with the same flavour. The one thing i do quite like with nespresso is the "specials" change nearly every time i order and the flavours are not "sweet" like the tassimo which is the worst coffee machine i have ever owned period! Im not even sure what made me buy it tbh. Alternatively, a Bialetti Moka is also a good choice.
