Spec Me A Complete System - £2000
21 Feb 2013
Hello,
I'd prefer something along the Asus ROG Hero board and the Corsair 650d.
Going to be used for gaming and virtualisation.
Will need complete tower, OS, peripherals and monitor.
Can go over budget if needed.
Was thinking around £400 on the Monitor + Peripherals and the rest on the System?
Thanks in advance.
Thanks micky
Just a couple of questions
Is the PSU fully modular? As I'd prefer it if it was.
If I went with a decent air cooler like a K2 etc, would the RAM have enough clearance?
Thanks micky
Im not sure if the psu is fully modular but i chose that because its gold rated and it will allow you to sli at a great price. If you went with the k2 cooler you would probably need low profile ram .
For the price the H100 works out a better choice, for cooling and noise plus you dont need low profile ram.
1.9k on a system with just a gtx 770?
It is still 350 quid worth of graphics card and more than capable at 1080p resolutions. By the time more power is really needed for standard 1080p gaming, there will be faster and better cards around than the 780 GTX.
It is a good choice. I have an HD7970 which is a bit weaker than the GTX 770, and really don't feel I have any need at all to upgrade my desktop GPU, and I like my eye candy turned up full and dont tolerate too many dropped frames from the golden v-sync'd 60FPS.
...he could spend an extra 200-250 on the GTX 780...but a lot of dosh for just a little bit more oomph....
I agree for 2k its much better to buy a prebuild and customise. 770 for 2k? Lol ive seen titan builds for 2k!
I know this is ocuk but look around and then ask them to price match. Theres way better builds then all of the above for 2k and they come prebuilt and oced!
The one im looking at now comes with razer mouse and keyboard, 780, surround sound, the acer monitor and the h100i too! Much better!
Link? (as long as its ocuk)
We have given the OP what he asked for, the case, quality monitor (well the Dell is, I don't know about the Acer further up) etc
Really?!
Considering the cards are £8-900 each, which is almost 2k, that is highly unlikely.
YOUR BASKET
1 x Sapphire HD 7970 VAPOR-X GHZ 6144MB GDDR5 PCI-Express Graphics Card £469.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor & Corsair H100i CPU Cooler Bundle with FREE Grid 2 PC Game £364.99
1 x Acer HN274Hbmiiid 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision Glasses £259.99
1 x Samsung 256GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD256BW) £193.99
1 x Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard £179.99
1 x Corsair Obsidian 650D Gaming Windowed Midi Tower Case - Black £149.99
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-19200C9 2400MHz Dual Channel Kit (TXD38192M2400HC9NDC-L) £113.99
1 x XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply £101.99
1 x Microsoft Windows 8 64-Bit DVD - OEM (WN7-00403) £72
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £67.99
1 x CM Storm Quickfire Rapid Mechanical Gaming Keyboard - Black Switch £60.38
1 x Corsair Raptor LM3 Gaming Mouse (CH-9000038-EU) £24.95
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £11.99
Total : £2,072.23 (includes shipping : FREE).
X79 + 780 Build food for thought, the monitor might not be a Dell but l have the 24" and l can't fault it. Going X79 6 core's + 16GB ram[Quad Channel] no worries about overclocking 4.5ghz, best of all no de-lidding due to the Haswell being hotter than Hades.
1x Corsair Obsidian 650D Gaming Windowed Midi Tower Case - Black £150
1x Seasonic X-Series 750w '80 Plus Gold' Modular Power Supply £130
1x Asus P9X79 PRO Intel X79 (Socket 2011) DDR3 Motherboard - £240
1x Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor - £480
1x Gigabyte GeForce GTX 780 3072MB GDDR5 PCI-Express Graphics Card - £570
1x Samsung 256GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD256BW) - £135
1x Patriot Intel Extreme Masters 16GB (4x4GB) DDR3 PC3-14900C9 1866MHz - £120
1x Prolimatech Megahalem CPU Cooler - £53
2x Prolimatech Blue Vortex Blue Wings 140mm Fan - £24
1x OcUK Value Blu-ray / DVDRW combi SATA - £48
1x BenQ GW2750HM 27" Widescreen LED Professional Monitor - Black - £215,
1X Microsoft Windows 8 Pro 64-Bit DVD - OEM - £115
TOTAL = £2280, l'll leave mouse and keybroad to the OP, spending that kind of money l would expect free shipping.
Something I quickly put together:
YOUR BASKET
1 x Gainward GeForce GTX 780 3072MB GDDR5 PCI-Express Graphics Card £539.99
1 x Iiyama Prolite E2773HS-GB1 27" Widescreen LED 1MS Monitor - Black £215.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail with FREE Grid 2 PC Game £194.99
1 x Samsung 250GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD250BW) £133.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £131.99
1 x Microsoft Windows 8 64-Bit DVD - OEM (WN7-00403) £72.00
1 x Corsair Vengeance Pro Blue 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9B) £71.99
1 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9) £71.99
1 x CM Storm Recon 4000 DPI Gaming Mouse £39.98
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Warranty £39.95
1 x Corsair AF120 Performance Series Low Noise High Airflow - Dual Pack £25.99
1 x Corsair Fan, SP120 PWM High Pressure Fan 4 pin, Dual Pack (CO-9050014-WW) £25.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £16.99
1 x Corsair AF120 Performance Series Low Noise High Airflow - Single Pack £13.99
Total : £2,006.71 (includes shipping : £25.45).
Shows you dont look around then.
I found a much better system then all the above with better kit but its not ocuk thats why I cant link but you could ask ocuk to price match them?
I wouldn't mind this pc myself! Has a haswell i7 aswell with a 256gb ssd. Comes with windows 7 or 8.
Then list the full complete specs?
