Spec me a CPU Cooler
4 Sep 2003
Hi there,
I'm current running an Abit NF7-S 2.0 mobo and will be in need of a new CPU cooler for an Athlon 2500-M CPU seeing as my CoolerMaster Aero 7 has died :o
I want something which is quiet but with good cooling as I will be overclocking the CPU. Budget of around £25-30.
Cheers
Ade :cool:
I think it is a mistake. On other websites it says it does support socket 462.
I didn't realise the Titan Vanessas worked with Socket A either. Why is the 120mm version cheaper than the 90mm version?
World's gone mad? It's Christmas? Who cares, it's good news :)
adsmithy - the vanessa is better at cooling, not sure about noise. Go for it if you have the cash.
Those coolers look beef cake. I'm a little worried however about the fitment as room is limited - please see pics.
There isn't much room between the CPU and PSU. What do you think?
Cheers
Ade
Oh **** you've got one of those that positions the cpu socket in the most awkward place ever. That's gonna be a bit tough :\
Just bumping this for suggestions on a compact air cooler that will fit (see pic).
I want to keep this case because eventually I will pass the system down to my dad when I upgrade which might be soon so don't really want to buy 2 new cases).
Cheers
Zalman CNPS7000B-CU Ultra-Quiet CPU Cooler - Retail £22.31 inc VAT
I allways used this with my barton and it did the trick no problems, i got it well above 3200 if i remember correctly.
Just double checking are you sure that will fit being a 92mm fan?
Heres the pic again, don't have much room at all :(
