Hi all,
As I'll be doing a fair bit of mileage soon, I figured it'd be a sensible idea to invest in a dashcam or two (front and rear). This thread is more to double check that I'm making the right decision!
My requirements are fairly basic, and I guess obvious for the most part:
The ideal solution would be a two channel unit, however from what I can see they're buggy, large, pricey, offer poor image quality, or all of those things. The ideal solution at the minute appears to be a couple of E-Prance Mini 0805s - great quality footage at night and day, reasonably priced (£180 all in with microSD cards) and reliable (it'd be the 0806 if it weren't for the plethora of issues). I know some others also have these units, however if anybody else has any recommendations then they'd be much appreciated.
I did long consider units such as the Blackvue DR650GW-2CH however the night footage is useless.
Many thanks in advance!
- 1080p/30fps recording both front and rear.
- Excellent capture quality at in the dark - England in the winter after all.
- Don't really need GPS, this will only be used for insurance/police purposes if anything were to happen (touch-wood nothing will), doubt anybody will be disputing where an incident took place.
- Compact!
- Parking mode not required, just using the 12V socket in the glovebox.
