Spec me a dongle for M1 MacBook Air
18 Apr 2003
England
Since upgrading to Monterey my £34 HDMI/PD/USB3 dongle stopped working with a mouse & keyboard but works with some USB memory sticks, though a Sony camera is no longer recognised so have to use the other USB C port & disconnect the keyboard while transferring photos. :rolleyes:
Actually, I use a 4 port USB3 switching hub as share keyboard/numeric pad/ mouse/USB sound card with a PC & just press a button to switch over to the Mac... These all worked with Big Sur through the dongle but not Monterey, but neither does a keyboard on its own.
Lucky to only be using a 1440p monitor so the usual 4k/30 HDMI is fine for 2k/60 :cool: I believe a 4k/60 dongle would be Thunderbolt3 & another £100 anyway.
Does anyone know of a dongle that works properly in Monterey that supports:
HDMI 4k30 2k60
PD pass through
RJ45 1000base
SDcard slot
2x USB3 A ports that work with a keyboard, memory stick etc
I know most the dongles have USB A ports but could do with a dongle that's been proven to work with Monterey & a keyboard at least.
From the rainforest £32 atm, not sold by OCUK:
USB C Hub 9 in 1, MAVINEX USB C Adapter 4K to HDMI, 100W Power Delivery, 5Gbps USB-C Data Port, 3 USB 3.0 Ports, MicroSD/TF, 1Gbps Ethernet Docking Station for MacBook, Dell XPS, More Type C Devices
Glad to report all ports are allowed with Monterey. Tests were done while also being fed a GigaLAN RJ45 + outputting to a 1440p monitor at 60hz + USB3 switching hub feeding USB sound card, keyboard, numeric keypad, mouse. The dongle gets warm but that's to be expected. Micro SDcard used: Sandisk Extreme Pro 128GB XC I v30 3 A2. The only slow result is writing with the SDcard slot, but how often do you do that.
Read 8GB file MB/sec
169 USB A from USB3 micro SDcard adapter (note: Win10/11 maxes out at 98MB/sec from any USB3 port on a Ryzen 3600x x570)
91 SDcard slot from same micro SDcard in a SDcard adapter
Write 8GB file MB/sec
86 USB A from USB3 micro SDcard adapter
26 SDcard slot from same micro SDcard in a SDcard adapter
