silane said:....snip....
Also the car didn't come with a d/v so I see no need to add one - surely Renault would have done so if it was needed.
ALL Renault Turbos come from the factory with a bosch recirculating valve fitted as standard.
Entai said:I know from experience even taking the standard recirc off an Audi A3 1.8 turbo, and just piping up straight, resulted in bits of compressor housing and blades being dug out of the bonnet, bulkhead, and surrounding areas after about half an hour of hard driving.
The whole housing and turbine grenaded itself due to compressor stall. because of the increased back pressure on accelerator lift off.
...pretty much sums up my thoughts on the subject.Stonedofmoo said:a hissing chav car
Stonedofmoo said:Do NOT use an atmospheric dump valve with the T7 ECU. Full stop
agw_01 said:Did you have a dump valve on your Pulsar stoned?
I'm seriously shocked at how the hell dump valves have been assigned a 'chav' link.
ci_newman said:Dump valves as a whole haven't been labelled as chav. Dump valves which make huge great big hissing sounds when changing gear (despite the complete lack of power in the car) are labelled chav.
playworker said:Must have been something wrong with the turbo for it to do that dude, there's no way that just removing the DV will cause that. I've run 1.4 bar for thousands of miles with no DV and the turbo didn't explode into little pieces. S13s don't have any form of DV from the factory running 10psi and the turbos last as long as on any other car. The compressor doesn't actually stall anyway, the noise is the air being forced back through the compressor blades, the speed of the turbo which is spinning at some ridiculous rpm isn't massively affected - it might slow slightly but it definitely won't stop dead.
Entai said:It was a brand new unit straight out of Turbo Technics workshop, the next two units did exactly the same thing untill we put the recirc valve back on.
Compressor stall does not mean that it will stop dead, it just means that you are forcing air into the unit from the wrong direction so the blades are chatering against the forced air.The compressor unit is not designed to be fed from the outlet and damages delicate internals if that is what you do.
If you mean the S13 engine fitted to Nissan 200SX's etc then sorry but they came as standard from the factory with a recircuating valve as standard factory fit, or so the FAQ's say at 200SX.org!!
See here, click on Enhacements in the menu on the left then look under the explanation for "BOV" - Blow Off Valve.
divine_madness said:Because virtually every time I hear (and im guessing most people) a 'psssttttcccchhh' sound, I inevitably turn around and see a what remarkably resembles a chav driving whatever car it happens to be...
Can't remember the last time I saw a decent car that looked like it was cared for with a DV on it.
agw_01 said:Not for me. I've seen one Punto GT Turbo, a few Starlet Turbo's, a few Rover Turbo's and the rest have been Skylines, Imprezas, Evos... etc...
I definitely see more turbo'd jap cars than Punto and Rover Turbo's.
Entai said:If you mean the S13 engine fitted to Nissan 200SX's etc then sorry but they came as standard from the factory with a recircuating valve as standard factory fit, or so the FAQ's say at 200SX.org!!
The later engines (SR20DET) are fitted with a recirculating BOV but they tend to leak over a certain pressure so are frequently binned with no exploding turbos to be seen
Phate said:Theres a few clios around here with dump valves, and some that just sound stupid.
But there are a couple of scoobys, the occasional evo etc and with a dump valve to me just proves a point that they are fast![]()
