Spec me a fan controller
19 Dec 2010
As the title suggest could somebody help me with deciding on a fan controller. The controller will have to be able to manage three fans on a channel as my rad is going to be set up in a push/pull config with the 3 fans from each side daisy chained together.
Thanks
Except won't you want 6 fans on one channel as I always thought you wanted the rpm to be the same both sides of a rad to keep the noise down.
would it not be better, for noise, and easier to control the fans in pairs? one on each side of the rad.
there is a second point to this that I hope someone pics up on :)
get 3 3pin y connectors which takes 2 fans into 1, then make sure u have enough power through the 1 connector to power both fans to full speed if you want them full speed! look for Watt per fan x2 then look for Max watt per channel on controller
this!
and also
I have this one Lamptron FC5 V2 granted my PC is not fully working yet but this fan controller is and looks awesome ! very impressed with it tbh.
As mentioned the Lamptron FC2 is a great no nonsense fan controller and could easily take all 6 on 1 channel, could also use them in pairs on 3 channels connecting the ones that are in line push/pull.
It will also take a pump on a channel if u wanted to add that.
