First off, yeah don't put a £200 gpu in UNLESS you're happy to upgrade pretty soon. Game machine = Wax as much as possible on the gpu, everything else comes second!
+buy 2nd hand if happy to, this'll avoid losing the most cash if you're doing the upgrade soon route.
I usually find around 50% of the budget for gpu is best, so you should be looking at a MINIMUM of an AMD 5700xt (£350ish) or 2070s (£500ish).
-Theres not much above those. 2080s @£650 is barely faster.
-I have NO idea what's up with the bonkers pricing on ocuk atm (£580 for a 5700xt?!?!) but i'm sure you could find one for £350.
"Tom Clancy" isn't too much help as that's a massive list of games, many are graphically intensive though and 5700xt will manage +60fps @ 1080p.
Mickeyflins build looks ok, other than gpu (he did say why a £200 gpu) and psu (I'd prefer 750w with the way gpus are going now - eg rtx3080 recommends 750w),
but it's still a dead end, feature missing intel build at the end of the day.
I haven't recommended anything intel in years, it doesn't look great tbh... A ryzen 3500x would be:
-cheaper (even with an x570 mobo)
-offer PCIe 4.0 (likely important for next gen gpus/ssds),
-AND most importantly: later on have the option to drop an absolutely bada** cpu in there...
Buuuuuut you dont want AMD for some reason... likely you've never had one and youre confused about AMD gpu reputation, their cpus have always been great.
So yeah IMO...
a) buy Mickeyflinns suggestion (with better gpu/psu)
or, my rec:
b) go AMD!!
£130 ryzen 3500x
£100/£140 any b550 / x570 mobo (*apart from x570 MSI ones!*)
£55 some cheap 3200mhz ddr4 - eg corsair vengeance or team group
£90 1tb sdd (nmve or sata, doesnt really matter atm).
£40 2tb hdd
*ocuk do WD £150 blue bundle (1tb nvme ssd + 2tb hdd)*
or £100 for 500gb + 2tb hdd)
£50 case (antec, corsair, msi, all do descent cases below £50, just google and choose one).
£80 750w psu (superflower leadex III, corsair rm750/rm750x can all be had for around £80-£100,
ttl=£545
ttl=£895 with 5700xt
