Spec me a indoor bike trainer!
16 Dec 2005
Halifax W'Yorkshire
Hey guys,
Iv been looking at these indoor bicycle trainers, the one's that convert your bicycle into a indoor bicycle type job.
Im an ex motocross racer and since I stopped racing iv become quite sluggish, but even back in my prime I was never a fan of cycling outdoors, I don't know why, i always used to go to the gym.
But now traveling to the gym with no motivation or reason to, it doesn't seem worth traveling 10 miles.
Where as if i had a bike sat in the living room there ready to ride always, it would make more sense for me, as it would be looking at me ready to use and id have no excuse.
Now, iv seen the prices of these thing's go from 30 pounds way up to hundreds.
Ideally, id want to spend about 50 on my first one ever just in case it turn's out i never used it after the hype of having something new, but if i did use it a lot then few month's down the line if needed if the cheap one wasn't doing the job very well due to low cost and quality, id ask the same question here again for something that's going to last and be better overall.
So for 50 pound's what can i be looking at? my bicycle aint nothing fancy just a 200 pound specialized from few years back but it should do the job.
Ideally the quietest trainer possible would be ideal, one that's easy quick release rather than one where you need to take the spindle out when you want to remove it from the trainer, as this bike is used 3 times per week by my friend aswell.
Thanks! :)
Edit: oops, i think this should have been posted in pedal power topic if someone can move it, my bad!
Definitely look second hand. A lot of people use them twice, get bored into submission by them (set it up in front of the TV...) then sell them.
They are not quiet, they are loud and are typically a non starter if you live in a flat with people living below. The 'quiet' ones are like the £1000+ tacx neo drive.
Also, turbo trainers where you run the rear wheel on a drum are very harsh on rear tyres - it's generally recommended to use a "turbo tyre (read: old worthless tyre) to avoid squaring off your road-worthy tyres.
How loud is loud would you guys say? Would the average cheap bike trainer be annoying?
Noise for the surrounding wouldn't be a problem, more of just a personal preference for my self, but I guess I could put my earphones in and listen to music.
Yep iv heard about the rear tyre, iv got quite a few spare tyres though that never have been used.
Also anyone got any links to recommended ones?
Mine isn't loud enough to go over the TV when I'm watching Sufferfest vids. It's not loud. On a wooden floor in a flat with grumpy neighbours maybe a problem but I've never had an issue. I can see how the noise would grate on someone else in the room thouhh
For £50 you're probably best off checking the local gumtree/etc listings to be honest. You might get lucky and get a second-hand fluid trainer rather than magnetic. Fluid trainers are both quieter and nicer to ride on in general.
Look second hand, you should find lots of bargains from those swapping out 'dumb' trainers for newer smart trainers.
Checking around locally you might even find one being flogged with a wheel & turbo tyre fitted so you could switch out your current wheel to save the tyres.
Personal opinion - if you're just spinning away rather than pumping up the resistance for specific power training you'll wear tyres less.
I have a friend who rides on the road and turbo with the same cheap-ish tyres & puts a new one on every year. Works for him, but he does get 4-5 punctures a year due to his poor well worn tyres...
