Hello,
I know there are a lot of threads out there about mechanical keyboards, but I'm looking or something quite specific, and can't seem to find what I'm looking for. Perhaps you've been looking for something similar:
Thanks!
- Cherry Blue or Brown (Blacks at a push)
- Steel backed construction (I bottom out a lot when I type)
- Backlit keys
- Laser etched keys at least but preferably dye sublimation keys or injection moulded.
- Simple design (not looking for a gaudy gaming one, but will consider if the above criteria are met)
- Full sized keyboard with number pad
Thanks!
