You're not going to get anything half-decent for gaming with that budget if you stick with Intel.
I'll have a think when I get home, but I think you'd be better off with a Kaveri APU system.
With the budget I have available, would I get anything better than what I am running at the moment?
I want something that gives similar, if not better, performance to the spec in my sig.
The main reason for doing this is to down size my setup, This is a huge beast at the moment.
Or this...which is probably the smallest ATX case:How much do you want to downsize by? Your case is pretty massive; there are small ATX cases out there:
YOUR BASKET
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £102.49
1 x Corsair Obsidian 450D High Airflow Mid-Tower Case (CC-9011049-WW) £91.99
1 x BitFenix Ronin Tower Case - Black £69.95
Total : £284.95 (includes shipping : £17.10).
Your Fractal XL: 560mm x 561.3m x 232mm (WxHxD)
Ronin: 483mm x 505mm mm x 205mm
450D: 494mm x 497mm x 210mm
540: 415mm x 332mm x 458mm
