Balls, you know what I hadn't even thought about cables! Will the SSD and BD not come with them at all?Do you already have one of these for the BluRay?
YOUR BASKET
1 x Akasa Slimline Optical SATA Cable (AK-CB050) £2.99
I imagine that's the right connector. Can't find the relevant info for that particular player.
The motherboard will have all of the cables you need, though that Akasa SATA cable will probably be needed
Great thanks for the heads-up everyone. I saw about the 'this week only' offers, Wednesday is an odd time for them to change?Yup. The motherboard will come with 2-4 normal SATA cables for SSD/HDD. The PSU will have the power Satas and molex. But you will need the right slimline-type connector the slimline BluRay.
There is no info on whether the BluRay will come with it. Could contact OcUK and ask them.
The weekly offers won't change till Wednesday so you have tomorrow to find out and still snap up the offers.
Currently having a bit of a panic over whether or not that Antec PSU is compatible with Haswell CPUs? I can't find anything out online?![]()
if your PSU is a quality unit, but does not meet Haswell specs, does that mean you need a new PSU to upgrade to Haswell? No, you do not. As mentioned earlier, you can disable the low-power states (or your mobo manufacturer will disable them by default), and you will be fine. - See more at: http://www.logicalincrements.com/haswell/#sthash.oX36O5nG.dpuf
Perhaps I would be better off/safer with the Superflower Golden Green 350W? Mind you I'm struggling to see for sure if that is compatible anyway! Sleep modes don't interest me on a desktop mind, is that all it is, essentially?Thank you for your webnote.
While this PSU should be fine for powering a Haswell system, it may not fully support all the low power states that HAswell brings. We would suggest contacting Antec who will be able to confirm if it offers full support.
Hmn, sounds a bit dangerous to me! This is what OcUK said from my webnote, agrees with you:
Need to order tonight!![]()
Sleep modes don't interest me on a desktop mind, is that all it is, essentially?![]()
I'm also struggling to find info on that player!Do you already have one of these for the BluRay?
YOUR BASKET
And both there and OcUK list it as having S-ATA connection. So I could take that to mean it has a 'normal' SATA connection?Samsung SN-506BB 6x Slim Internal Blu-ray Writer with SATA - OEM
