spec me a multi screen setup
9 Jun 2009
London
Hi I am looking to run 5 monitors off one box, what would be the best way to do this, 3 gfx cards :confused:
They are nothing doing anything special really so the cards don't need to be that hungry, just wanted a stable solution, anybody got experience on this, maybe including the motherboard in the spec, would probably go for a i7 in the build.
Help wouldn't be much appreciated, don't have a budget but don't go wild.
Would the Eyefinity 6 Edition 5870's be a good solution, huge overkill but simple.
If you can afford it, bearing in mind the displayport monitors are usually a bit more expensive than other, an Eyefinity 6 5870 would be the most elegant solution :)
Could you fine people please check my spec,
note the dvi connectors are there because I am waiting on OCuK to tell me how many are included.
