spec me a nas drive
28 Oct 2002
Hiraeth
Im toying with the idea of building a NAS as I store loads of photos. I already have a 2tb drive which is nearly full.
I have an old c2d box with 6 gb of ram so thought about freenas or something like that.
Looking online, there are server variants of hard drives available for a lot more than their standard counterparts, so I was wondering, don't modern drive like being left on 24/7 or is is a marketing gimmick?
What would you recommend for a 24/7?
WD have created the 'red' range of drives specifically for NAS boxes. I see a lot of people swear by them and supposedly they're designed to be left on permanently.
For a fuss free solution, Synology are fantastic.
I still have a Windows based server which I use for extra backups, but I only power that on for about 1 hour per week.
My Synology is on 24/7 and only uses about 15-20 watts :)
Then use WD Red drives with it.
Definitely go for the WD reds. I have just set up a HP microserver using OpenMediaVault. It was much less grief to get up and running than freenas. I found this guide really helpful.
Sorry to hijack this a little (though my question is very much on-topic and it seems unnecessary to create another thread so similar).
I am also looking for a NAS solution to store all my films, home videos, photos and music on for streaming to my HTPC and upstairs to where I intend to set up a cheap Pi XBMC box for the very rare occasion we want to watch something in bed.
I notice the D-Link DNS 2-bay line seem quite significantly cheaper than anything else. Is there any reason for this? I don't see them recommended much, but if it works, it works, doesn't it?
I know very little on this side of things (this will be my first NAS), and would like if possible to do it on a budget as I also want to put together an i3 NUC soon to replace my HTPC.
I can't comment on the specifc D-Link as I don't know much about them but I would say you get what you pay for with NAS boxes.
The Synology interface (DSM) gets rave reviews which makes them really easy to use plus you can download and run some applications on the NAS which is really popular. Other key element is around the speed of read/writes. I'm sure with a little searching you could get the data for both to compare.
