- 27 Feb 2006
- Normanton
My TP link W8910G wireless router is crap, ive tried for hours to get it to work, updated the firmware and done exactly what it says in the manual. It still wont find an ADSL connection, then I plug my origo wired router back in with the same line wire and it works straight away.
What is a good wireless ADSL router that has good range and at least one RJ45 port for connecting to a PCs ethernet port. Needs to be a plug in and follow simple instructions jobby that finds ADSL connection
Thanks
Thanks
