Spec me a pc £2000 max
20 Jul 2006
County Durham
Can someone spec me a pc for a budget of £2000 max
Must Include
Processor
Motherboard
2 gb memory
vid card
sound card
hard drive
dvd rom
dvd writer
case
psu
monitor
floppy drive ( or alternative)
CP-128-IN Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN)
£214.95 £214.95
MB-061-GI Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard (MB-061-GI)
£89.95 £89.95
MY-058-GL GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
£124.95 £124.95
GX-047-CO Connect3D ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (3056) (GX-047-CO)
£179.95 £179.95
CA-024-EN Enermax Liberty 620W ELT620AWT ATX2.2 Modular SLI Compliant PSU (CA-024-EN)
£87.95 £87.95
CA-069-LL Lian-Li PC-S80B Black Aluminium Full Tower Case (CA-069-LL)
£148.95 £148.95
CD-030-NE NEC ND4570 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-030-NE)
£21.95 £21.95
HS-003-SY Scythe Ninja Plus Heatpipe CPU Cooler (Socket 478, 754, 939, 940, LGA755) (HS-003-SY)
£31.95 £31.95
HD-083-SE Seagate Barracuda 7200.10 400GB ST3400620AS SATA-II 16MB Cache - OEM (HD-083-SE)
£107.95 £107.95
SC-034-CL Creative Sound Blaster X-Fi Xtreme Music - Retail (SC-034-CL)
£71.95 £71.95
KB-060-LG Logitech MX518 Gaming-Grade Optical Mouse (KB-060-LG)
£29.95 £29.95
KB-054-MS Microsoft Comfort Curve 2000 Keyboard (KB-054-MS)
£11.95 £11.95
SP-034-LG Logitech Z-5450 THX® Certified 5.1 315 Watts Wireless Speakers - Retail (SP-034-LG)
£204.50 £204.50
MO-060-VS Viewsonic VX2235wm 22" Widescreen LCD Monitor - Black (MO-060-VS)
£299.95 £299.95
FG-008-AF AcoustiFan C-Series Ultra Quiet 120mm Fan - 3 pin (FG-008-AF)
£7.95 £7.95
FG-006-AF AcoustiFan C-Series Ultra Quiet 80mm Fan - 3 pin (FG-006-AF)
£4.95 £4.95
OS-002-MS Microsoft Windows XP Professional Edition inc. SP2 - OEM - 1Pk (E85-04026) (OS-002-MS)
£81.95 £81.95
Subtotal £1,721.70
VAT £301.30
Total £2,023.00
I specced this up for someone in another thread- take off the speakers, keyboard and mouse and it comes in well under budget :)
Nice spec, though I would say it would be better to get 2 250Gb HHDs, only a couple of quid more and you get much more versatility (ie a RAID configuration depending on what you need).
Also, though that Lian-Li case looks the dogs, I'm not convinced it's worth spaffing £175 on irrespective of budget.
Perhaps a dual monitor setup would be nice too, though it depends what you need from the system. If it's going to be a media type PC, perhaps 1 large monitor would be best, but for most other uses (especially desktop work) dual monitors would be a big bonus.
Ahh sorry- the Lian-Li case and the case fans were something the person I originally did the spec for wanted specifically but of course these can be changed to suit your tastes. Personally, I would never consider spending that much on a case but that's just me being a cheapskate :o
Nuttie, do you need a massive HDD? 400GB sounds cool but if you're like me you'll probably not use more than 50GB so if you're not planning on using the space it's just basically an E-penis-pump if you get my meaning.
Trigger said:
Hard drives are comparitvley cheap these days though so it makes sense to have more space than you need ;)
it does and they are pretty cheap but for someone like me my 160GB HDD is much more than I'll ever use I think, 115GBs free and I've got everything I need on here. However if you like downloading videos/music and whatnot the space is filled up a lot quicker.
Still, if he's not gonna use the space that £50 could be either saved or spent on some other component.
The spec. trigegr gave are ok
Into the other reply's:
if your a downloader, go for 400 gigs at least, it will fill up in a approx. 2 months if u take anything less.
If your not a real gamer or downloader: 160 gigs is all you need ;)
, also why a floppy, its all replaced with bootable cd's. a rewritable cd can do anythign a floppy can and 400 times more data fits on it.
But if you realyl wnat one, try soem advert sites for a cheap one for 5 quid or less... , whatever the case unelss u destroy bios u'll never need floppy's, they're pretty obselete...
Even a USB memory stick would be more worthwhile than a floppy drive, not many new computers have floppies now.
probs just put a card ready where the floppy should be, as for the hardrives i do download a lot and game when i get the chance, iam wanting a really fast hd, like one of those wd raptors, what u think
