Spec me a pillow
18 Apr 2011
Need new pillows, just looked in the Argos catalogue and there's so much choice, duck vs cotton vs polyester.
Any recommendations, I'm looking to spend about 20 quid for two pillows, with a small bit of wiggle room if it's gonna change my life...
i got fed up of buying normal pillows, they all go flat or lumpy after about 2 months, so i got a silentnight memory foam pillow, much better
Sod feathers in a pillow absolutely stupid idea, go for Microfibre or Memory foam, I have tons of different pillows of an assortment.
I find the memory foam too hard to sleep with so I use a medium microfibre
I've always gone for the 'Dunlopillo'
Keeps it's shape and firmness and doesn't get those empty areas you can get with feather!
I wouldn't use anything else now.
You need to go into a bed shop or similar that has the pillows on show to see what they feel like. It's all personal preference.
I love my feather and down pillows, but other people have complained that they swallow your head.
