* 10 mm detachable hexagonal wrench - Screwdriver - Spoke key (3.3 mm and 3.5 mm) openings - Extension lever 10 mm detachable hexagonal wrench - Screwdriver - Spoke key (3.3 mm and 3.5 mm) openings - Extension lever
* All-purpose wrench (exclusivity) All-purpose wrench (exclusivity)
* Bit holder Bit holder
* Blade with blunt point Blade with blunt point
* Can opener Can opener
* Case opener Case opener
* Chain rivet setter Chain rivet setter
* Cigar cutter (patented) Cigar cutter (patented)
* Club face cleaner (exclusivity) Club face cleaner (exclusivity)
* Combination tool : Screwdriver with safety lock system (exclusivity) - Can opener - Cap lifter Combination tool : Screwdriver with safety lock system (exclusivity) - Can opener - Cap lifter
* Corkscrew Corkscrew
* Curved hexagonal key Curved hexagonal key
* Detachable marker Detachable marker
* Fish scaler - Fish disgorger - Lineguide Fish scaler - Fish disgorger - Lineguide
* Flat Phillips screwdriver Flat Phillips screwdriver
* Flat pliers Flat pliers
* Flat screwdriver 3.5 mm with safety lock system (exclusivity) Flat screwdriver 3.5 mm with safety lock system (exclusivity)
* Flat screwdriver with safety lock system - Cap lifter - Wire bender Flat screwdriver with safety lock system - Cap lifter - Wire bender
* Graduated tread depth gauge (mm/inch) uses detachable sliding bit holder Graduated tread depth gauge (mm/inch) uses detachable sliding bit holder
* Green repair tool Green repair tool
* Green repairer Green repairer
* Integrated holder Integrated holder
* Integrated swivelling compass with sight line (exclusivity) - Ruler cm + inch (exclusivity) Integrated swivelling compass with sight line (exclusivity) - Ruler cm + inch (exclusivity)
* Junior round blade Junior round blade
* Large blade Large blade
* Laser pointer Laser pointer
* Magnifying glass - Precision screwdriver Magnifying glass - Precision screwdriver
* Medium screwdriver - Cap lifter - Wire bender Medium screwdriver - Cap lifter - Wire bender
* Metal file - Metal cutting saw Metal file - Metal cutting saw
* Nail clipper (exclusivity) Nail clipper (exclusivity)
* Nail file - Nail cleaner - Screwdriver for small cross head screws Nail file - Nail cleaner - Screwdriver for small cross head screws
* Needle nose pliers / Wire-cutter / Nut wrench Needle nose pliers / Wire-cutter / Nut wrench
* Phillips screwdriver Phillips screwdriver
* Phillips screwdriver with safety lock system (exclusivity) Phillips screwdriver with safety lock system (exclusivity)
* Reamer Reamer
* Reamer - Eye Reamer - Eye
* Reamer - Needle - Cuticle pen Reamer - Needle - Cuticle pen
* Ring Ring
* Safety lock system (patented) Safety lock system (patented)
* Semi-round-nose pliers - Wire-cutter - Nut wrench Semi-round-nose pliers - Wire-cutter - Nut wrench
* Serrated-edge scissors and lever (patented exclusivity) Serrated-edge scissors and lever (patented exclusivity)
* Shackle opener - Marlin spike - Ruler inch/cm - Needle Shackle opener - Marlin spike - Ruler inch/cm - Needle
* Shoe spike wrench Shoe spike wrench
* Slip-joint pliers (exclusivity) - Wire crimper - Inside and outside wire cutters - Nut wrench Slip-joint pliers (exclusivity) - Wire crimper - Inside and outside wire cutters - Nut wrench
* Small blade Small blade
* Small blade 65 mm Small blade 65 mm
* Small screwdriver Small screwdriver
* Snap hook Snap hook
* Special blade Special blade
* Spot light Spot light
* Stroke counter with 12 graduations Stroke counter with 12 graduations
* Toothpick Toothpick
* Tweezers Tweezers
* Wood saw Wood saw
