Nope, not at all. The GTS and E6600 are rather light on power consumption. I recommend the HX 520 to people with overclocked Q6600s and 8800 GTXes and it does a cracking job.Dont you think I should go for the 620W?
Nope, not at all. The GTS and E6600 are rather light on power consumption. I recommend the HX 520 to people with overclocked Q6600s and 8800 GTXes and it does a cracking job.![]()
Yes. It does depend on what other things you have in your system, but an average OC'd system (one or two HDD, one or two ODD, one GPU, and a mild overclock) would do just fine.^^ Are you sure mate, I created another thread asking the same question. It would be much cheaper for me.
What PSU calculator did you use? The one I see used most often is this: http://www.extreme.outervision.com/PSUEngineYea, it's really one SATA HDD, 1x DVD RW, 2x 120mm fans and maybe 1x80mm, that's for the case. Along with the Q6600 and the GTX.
I used a PSU calculator and it showed me that I need 600w, at least.
Oh and no overclocking.
Also, what you guys think of the Thermaltake 750w
I am really sorry OP for hijacking.
I just plugged in your proposed rig and it said 305 W.
Hehe, that's wierd, I got the 540 for the same thing. Anyway, will probably go with the 520w. Will think about it!
OHHHHHHHHHHH, you used a single CPU.
Ok, now that was stupid. I got same as you, thanx man.
