- 20 Feb 2009
- Ashton-Under-Lyne
First off, I apologise for the mass of questions, so I tried to split it up with some pretty pictures
I think I'm finally getting on with it, and I would like to order my WC system this week, so I can set it up next weekend (hopefully)
I'll be cooling:
2500k
6950 (flashed to 6970) (possibly to Crossfire in the future)
In a HAF-X
What I have so far:
Anyone have any comments on this? Anyway to improve it, without it costing a bomb?
Only thing I'm unsure about, is the radiator (Although I know I'll be getting a triple). How difference in performance is there between the ones at £45-£50, and those that are almost double that?
Would I be ok with one of the cheaper ones with what I'm cooling? I'm pretty sure the cheaper ones wouldn't manage CF, but would the more expensive ones, or would I need to get another rad if I got CF anyway?
From a google, I don't seem to be able to find any recent radiator comparisons, the newest I could see was 2009!
The layout I was planning is this:
Lastly, I was thinking of getting some extra fans to attach tot he bottom of the radiator, in push, to add to the 2x200mm fans I have in the top of the case in pull. Is this a good idea? Which ones should I go for?
Think that's all for now, hopefully someone can give me some help
I'll be cooling:
2500k
In a HAF-X
What I have so far:
I highly doubt they'll be quiet at all, even on a fan controller, as on minimum, it'll probably still be running at 2-3k...
