Hi guys,
I'm currently running a 9900k @ 5Ghz using the silent loop 360 coupled with 3 silent wings 3 pwm fans. Can't quote exact temps as I'm not home but they're higher than I'm happy with on average. Will also thermal throttle when running prime within 30 minutes.
Problem is I've had the aio less than a year and keep I keep getting trapped air noise despite trying to fix the problem by up ending the loop, shaking it and even topping it up.
What do you guys recommend as a replacement?
