Spec me a replacement machine
15 May 2010
Out of Coventry
Story here:
http://forums.overclockers.co.uk/showthread.php?t=18465990
Basically I've had simultaneous multiple component failure, and need a new PC.
I already have a new PSU (600W), and I'm pretty sure my hard drives are still functioning, and my case still does the business. Unsure about my RAM.
So that means I need a new Motherboad, CPU, and GFX. I figure since I'm buying new components anyway, I may as well get new RAM too, as I fancy having 8Gb, and its pretty cheap.
Performance wise I'm not that fussed. Previously I was running a AMD 965 + 5870, and that was enough power for everything I did. So I'll be looking at getting components to a similar/slightly greater performance than this.
From what I've seen, Intel is king at the moment, but the sheer range of different Intel motherboards is a bit daunting.
So basically I need a new:
CPU
Motherboard
Graphics card
RAM (8 Gb)
No budget has been set, but the lower the better, performance shouldn't be lower than my old machine.
Cheers!
the second does not need a GFX, watch this video
The Intel build is better, i recommend the AMD to people on budgets but want to play the latest games.
Opinions on this?
YOUR BASKET
1 x Asus HD 7870 DirectCU II V2 2048MB GDDR5 PCI-Express Graphics Card £199.99
1 x Intel Core i5-3330 3.00GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £139.99
1 x MSI Z77A-G43 Intel Z77 (Socket 1155) DDR3 Motherboard - FREE Alpenföhn Civetta Cooler!! £79.99
1 x Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9B) £49.99
Total : £481.37 (includes shipping : £9.50).
I've just realised that my monitors use DVI connections, so I chose a GFX card here that has two DVI slots.
If you not fussed about overclocking the 3330 would be ideal...
If you're spending £200 on a GPU (with 2 DVI ports) the 660ti is a good choice too..
Get Lower profile RAM, Tall RAM can interfere with air coolers. (if you decide to get one) :)
YOUR BASKET
1 x EVGA GeForce GTX 660TI 2048MB GDDR5 PCI-Express Graphics Card £219.95
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £89.99
1 x Avexir Blitz Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (AVD3U16000904G-2GW) £39.95
Total : £501.28 (includes shipping : £9.50).
Cheers for the RAM advice. The same motherboard has been recommended twice now, is it that much better than the cheaper one I posted? The choice of intel chipsets is pretty confusing these days.
Just checked out the benchs on the Nvidia card, seems slightly better, but I think I'll stick with the 7870 as I already have AMD drivers installed and don't want to risk confusion.
They both use the same Z77 Chipset (top chipset for 1155) but the D3H is the Best reviews Sub £100 Z77 Motherboard. Also Gigabyte have UK service and RMA, Win Win...
That's as a good reason as any. :)
I would be looking at a 3GB MSI/Gigbayte Radeon 7950..shame RAM isn't on sale at the moment, or you can drop down mobo to Asus P8Z77-V LX there won't be any difference in performance so no need to spend £90
