Hiya everyone,
Am looking to purchase some components for a new system i intend to use as a Digital Audio Workstation (Music Production). I usually have no problems picking out the right components and building my own system, however after reading tons of reviews on quad core intels, motherboard and ram - it literally has got my head spinning.
I was wondering, if i give you a budget of £3,000 +/- £300, would you recommend the best spec i could get for that price. I only need a bare bones machine, no monitor or soundcard is needed.
As this system is for a DAW, i need noise to be at a minimum. So the quieter the better.
I'll start the spec off :
* Intel Quad QX9650
* mobo ?
* 4 Gig Ram of ?
* ATI Radeon HD 2600 XT
* Seagate Barracuda 1 x 1TB
* Seagate Barracuda 3 x 750 or 500GB
Whats the difference between the ES.2 and the 7200 ?
What power supply / case do you recommend ? - quieter the better
Thanks for your time ....
Vinney.
* Intel Quad QX9650
* mobo ?
* 4 Gig Ram of ?
Vinney.
. Might need a hefty PSU like 1000W.
