Spec me a water block
12 Sep 2005
Grundisburgh
If this should be in a different forum please move it mods.
I want to quieten down my 980ti's. last time I got to this point is cooling I had GTX480s and water did a really good job.
I have the EVGA ACX cards so not the type that is simple to cool with a hybrid kit.
Has anyone done their 980Ti's for noise reduction.
Andi.
I just done my 980Ti ACX Superclocked+ with the Nickel Titan X version posted above. Fitted fine and was easy enough. Something to point out, if you want to use the EVGA backplate with the EK block you need to buy some different bolts and they won't sit flush. I ended up buying the Titan X backplate for mine which is a perfect fit.
