Spec me a water cooling kit please
26 Jun 2010
Hartlepool
Hi Guy`s
I am looking into water-cooling the rig in my specs
must be a slim 120x3 rad to fit in the top of my Fractal Design R2 case
a pump that will run a 360 + 120 rad When i get money for GPU block
1/2" or 5/8" O/D white UV tubing
reservoir (not a bay)
and Gold coloured fittings (compression) if poss to match the mobo
i have fans (Fractal Design)
£200--£260 budget.
No problem.
The OcUK kits are the sort of thing I'd go for anyway but they bundle them and give you a cheaper price :)
The EK kits are averagish. These kits are fantastic.
