Spec me a workshop respirator
23 Nov 2007
Lancashire, UK
It is with great sadness that my single filter Safir Sussex mask has succumbed to age, and the rubber of the mask is really giving up the ghost. I therefore need to replace it, but thought I'd seek opinions on what is currently on the market before I buy anything.
Previously I've always used the Safir Sussex stuff, so I'll just buy the same again unless anyone else comes up with anything.
Requirements:
- Mask only, as I'll be using a separate visor
- Grade 2 filtration only really, it's for woodwork so only need 1 for most things, but P2 would be handy for when I have to dabble with the evil that is MDF etc.
- Must be comfy. Must be comfy. Must be comfy.
That's about it to be honest. Cheers!
My Safir Sussex R300, suffered the same fate last week, strap broke in two places.
Been looking for a replacement for a week, & I still can't decide what to replace it with.
So far, on my list I have 3M Half Respirator 6200 with P1 filters, have also looked at Scan Twin Half Mask Respirator, but P1 filters are hard to source, so I have rule them out.
Had a look at a MOLDEX 7000 series respirator, but my local shop didn't stock P1 filters to fit.
So, it's looking like 3M,as filters are readily available.
http://solutions.3m.co.uk/wps/porta...369UJT2UU4000000_nid=HXFN27ZB38beZ2F9CWGGTPgl
I have a 3M 6200 half mask. Find it pretty comfortable even for long periods.
Had a look at one this morning, I like the idea of it being available in 3 sizes (small, medium, large), so much better than one size fits all.
Found it very comfortable to wear,& seals much better than my R300.
Thanks for the replies guys!
I was looking at the 7500 half before, wasn't sure the 6200 looking comfy enough, so that answers that question! For spare filters, is eBay a safe bet or do these get counterfeited? I usually buy my gear from J&L, but they only do bulk boxes of filters!
I realise disposable masks are cheap, but I'm surprised the proper half mask offerings aren't more commonplace given the advantages they give for the hobbyist or regular tradesman.
I think I'm actually set on the 7500 now - it's the model up, and I can get it for £17, so £3 more than the 6200 would cost me.
I'm still struggling to find sizes though - nowhere near me stocks these, so trying on isn't an option, I need to know what head measurements to take and what fits what! I'll keep looking and post back for the record if I find anything.
They're great, I've got one at the moment, it's just that in the long run they work out a long more expensive, and when you spend a lot of time in the workshop for pleasure, it's a big cost! I'm not too worried about swapping them, that's what the odd wipe over is for :).
Yes, I suppose it's a different matter when you're sharing a paintshop with other guys and there's always that chance of picking up someone else's mask!
I use 'Dettol Antibacterial Surface Wipes' to wipe around my respirator.
The 3M 7500 respirator is available in three sizes, small 7501, medium 7502 & large 7503.
