Spec me an Android Phone ~£250
Don
19 May 2012
Spalding, Lincolnshire
Afternoon All, just after some help choosing a new phone.
Currently have a Nokia 8, which whilst it hasn't been receiving any updates for a while, does everything I need it to do - it's still pretty fast, has a great screen, good build quality and isn't too big to fit in a shirt pocket.
Only downside is the battery now doesn't seem to be holding charge particularly well and doesn't seem worth replacing.
My budget is around £250-£300 (The Nokia 8 cost me £250 and that was the most expensive phone I've owned :D), but would like something similar that is going to last another 3-4 years.
- I'd prefer a phone similar size to the Nokia 8 (151.5mm x 73.7mm x 7.9mm) but appreciate there aren't many choices in that regard, so may have to compromise.
- 5G handset would be preferred for a bit of longevity, as would a reasonable amount of RAM (probably at least 6GB?)
- microSD slot (as I've always stored photos/music/crap here rather than "wasting" faster internal storage), 64GB storage has always been fine on my Nokia 8 as a result
- Decent battery life
- Not particularly bothered about the camera, as long as it's reasonable - certainly don't "need" a 50MP+ sensor - I have a DSLR that I do any "decent" photography with
The models I've seen so far that meet most of the criteria are:
- Samsung Galaxy A33 5G - historically not been a fan of Samsungs due to bloat and again slow/not guaranteed OS updates. Android 12 OOB, Fastest processor/GPU I think of these - £300
- Moto G82 5G - "safe" choice, as my Wife and Kids have Motorolas, I've had Motorolas before, but the length of support/speed of new updates always seems to have been a problem? Comes with Android 12 out of the box though - £280
- Xiaomi Redmi Note 11 Pro 5G - Good software policy (3 android releases + long security update period?), Premium looking. Negatives are the size and unsure on the OS "Skin" - £250
- Pixel 6a - Releasing soon, stock Android, long official support (+probably 3rd party support afterwards), reasonable specs, Perfect Size. Downsides are much worse Gorilla Glass on the screen? No microSD slot And obviously cost - £399 is a big jump and not sure if it's worth the extra?
I think the Nokia XR20 is on offer at the moment for £270
I ruled that out as it only has a 4xx series Snapdragon and 4gb ram, so probably no faster than my current Nokia 8.
The Poco X4 Pro should be ok, and at £159 (normal price £259) then even if only keep it for a year or so, I'm not going to feel like it's money wasted.
I thought it had 6GB of RAM, maybe I'm getting the X20 and XR20 mixed up, might be worth double checking but yeah the hardware isn't the best spec compared to some others and they were released over a year ago now
Poco nice phone once ads removed /debloated had the M4 for short while but upgraded to F3 on special. Get on fine with Miui13 on Android12 though look forward to custom ROM at some stage
