TomB, you do realise that OCUK build computers? Have you contacted them direct?
I would certainly rather buy through OCUK than the other company your looking at...
This 100%! And get GTX card over the Quadro to save some momey, the GTX's perform very well.
You ahould be looking at a Seasonic/superflower/Evga PSU over Corsair offerings as they're not a great OEM anymore.
What other power supplies can you choose, only Corsair ones? RMi are also CWT, not to say they are bad but you can do better![]()
I would opt for air cooling the CPU rather than AIO, As this is a work machine you want to minimise the fallout. One of the large Noctua heatsinks will out perform the AIO anyways.
(This should help with reducing CPU trottle when you are rendering.)
https://www.pugetsystems.com/labs/articles/AutoDesk-Maya-2014-Professional-GPU-Acceleration-509/
Just reading this, the Titan GTX is really badly rated for MAYA but the cheaper AMD cards are out performing the NVIDIAs
I wouldn't trust a performance chart created by a company who are trying to sell you 'workstation' cards. The spec benches are not really relevant to today's viewports. As I said before, Maya is pushing viewport 2 in a big way which is opengl/directx11.
That said the amd cards do get you decent viewport performance, but you lose the benefit of cuda.
Those Noctua's are good a cooling but I'm not a fan of putting all that weight on the CPU socket. I have a Asaka Nero cooling a Q6700 for a few years and when I took out the motherboard it had warped under the strain caused by the weight of a mid sized cooler. As a result I would never go back to large ass heatsinks, AIO's are a smaller and more elegant solution and give you the best results bar dedicated custom water.
most of the adobe suite can be accelerated with cuda, and if you're looking at rendering a lot of frames it could be very useful for rendering - mental ray now has a gpu-accelerated gi, most of the current crop of gpu-renderers use cuda right now. I'm using redshift3d which has cut rendering times drastically with a couple of titans.
