- 6 Sep 2016
You don't seem to get that for the vast majority of people a high end soundbar system is vastly preferred, they are mostly plug and play without tons of settings to mess with, you usually get rears without having to trail cables around the room, they give massively better sound than the built in TV and with the likes of eARC don't need upgrading that often.
With his budget and the fact he seems quite new to audio I'd be looking at a high end soundbar and I'm sure he'd be happy. An AVR is going to eat most of his current budget leaving him with low end speakers.
Just looking at Very he could get a Sonos Beam, Sonos Sub Mini and 2 Sonos One SL for £889 assuming he's not used the new customer 20% off code before.
Which would get him a very good set up, with no trialing wires as long as he's got power sockets close to the speakers and is extremely easy to set up and gets monthly software updates and is less intrusive than a separates system and he won't have to find room for a huge AVR.
I'm sure if you have the room and the budget then a separates system makes more sense, but for the vast majority a high end soundbar is more than enough.
Just admit your wife wears the trousers and you're not allowed to buy JBL Everest DD67000 and you're trying to make excuses.
I'm sorry you are not allowed to enjoy a home cinema speaker system.
Sonos are overpriced, cheap rubbish, locked in eco system, that subwoofer is barely a subwoofer with dual 6" woofers. It's also all plastic crap. It's also a rubbish home audio streaming system as they are too stingey to increase the RAM in the units to support more than 65,000 tracks in your home library. Also have you forgotten what they tried to do with their system a while ago?
Since this is a PC forum it would be like you saying gaming on a single core PC with 2GB of RAM and integrated graphics is an acceptable gaming machine, nearly as good as a £2000 gaming PC.
You're also forgetting E-ARC can cause issues you need a TV that passes all formats. Some TV's don't pass DTS. E-ARC is ok as an additional output/input, but forcing yourself to use it because a crappy soundbar only has one input and no outputs is stupid.
I've spent less on my speakers than that Sonos soundbar, and they will offer far higher build and sound quality. Hell they're real wood, veneer, and high end drivers, not in a crap plastic encosure with 2" drivers. That BK subwoofer 10" is something else than than Sonos "sub"
Oh it doesn't need speaker cable trailed around the room, but it needs a power cable trailed across the room, and power sockets near also hahaha .
Can you re-use those Sonos speakers later on with non Sonos gear?
OP just buy a AVR and 5.1 speaker system, they don't know what they're talking about. You can get pretty good bargains, if you're willing to buy second hand, and if you don't like one part- say you bought Klipsch speakers and you hate them - just replace those Klipsch speakers keeping the AVR, subwoofer, rears.
Once HDMI 2.2 comes out, just replace the AVR. Those with TV's that drop DTS support on E-ARC means they'll just get stereo PCM from their 4K movies haha, and you'll have full DTS-MA, DTS;X, etc or if DTS X 2 comes out change the AVR, they'll have to junk their whole soundbar. And if they buy another brand of soundbar, their Sonos sub and rears won't work hahahahaha
Have a think about what you can get away with in your lounge in terms of number and size of speakers, and then go from there. I've only got 5.1 but I love it. To me it sounds ace. It is an actual lounge and not a dedicated cinema room, so we had fairly strict requirements to have stealthy speakers so it is a compromise. Works for us well.
